vcStatementHelper
Helper class that contains functions to get active scope and routine.
Module: vcRobotics
| GetActiveRoutine | vcRoutine | None | Gets the active routine based on the selected objects in vcSelectionManager. Returns: vcRoutine: The active routine. Can be None. |
| GetActiveScope | vcScope | None | Gets the active statement scope based on the selected objects in vcSelectionManager. Returns: vcScope: The active statement scope. Can be None. |
| GetActiveStatement | vcStatement | None | Gets the active statement within the active scope. Returns: vcScope: Statement scope. Can be None. |
| GetActiveStatementIndex | Integer | None | Gets the statement insertion index within the active scope.See moreReturns: int: Active statement index within the active scope. -1 if there is no active statement. |
